engineerex.decorexpro.com/en/
Water supply
Filters and water meters
Pump equipment
Well and well
Water pipe
Pools and fountains
Other
Heating
Heating Wiring Diagrams
Boiler room equipment
Boilers for heating
Water heaters and boilers
Design and calculations
Radiators and heaters
Floor heating system
Insulation and insulation
heating equipment
Other
Sewerage
Storm sewer
Wells and piping
Drainage systems
Rake and drain pit
Household buildings
Sewage pumps
Other
Electrician
Theory and Documents
Cables and wires
Wiring
Electric meters
RCD and machines
Relays, contactors, sensors
Sockets and switches
Lamps and bulbs
Antenna equipment
Gasification
Calculations and standards
Security questions
Installation work
Documents and Design
Gas equipment
Ventilation
Air conditioning systems
Ventilation equipment
Installation work
Eco energy
Solar panels
Wind generators
Heat pumps
Biofuel
Eco house
Appliances
Washing machines
Vacuum cleaners
Dishwashers
Refrigerators
Climatic equipment
Expand
home
FAQ
Water supply
Wells and wells
Turbid water in a new well - do you need a bottom filter?
Alexander
124
Which pump to choose for a well in 7 rings?
163
How to replace the BC 1.1 surface borehole pump?
Nikolay
134
What do you recommend a pump for a 15m deep well?
Maxim
170
Which pump to install in a well with an iron content exceeding the norm by 1000 times?
Nina
238
Water is supplied intermittently from the well - what is the problem?
Sergei
292
Why is rusty water coming from a 90m deep well?
Sergei
324
Why do we need holes in the well pipe above the filter?
Boris
227
Is it possible to drill wells using a Bobcat-based Yamoborer?
Dmitry
Why is there no water in a 30 meter well?
Alexander
224
Questions on the specifics of auger well drilling
Mark
224
Which pipes are best suited for feeding a deep well into two towers?
Ruslan
160
How to choose a surface pump in a 30-meter well for watering the garden?
Valera
179
Which pump to install to increase the pressure of water from a well-needle?
Irina
195
How to choose a pnd pipe for equipping the water supply base from the well (650m)?
Sergei
201
view
Which heating cable to choose for a pipe in a water supply system from a well
203
Pressure drops in the water supply system (well + pump “Aquarius”)
Ivan
309
What to do if the check valve in the well lets water through?
Stanislav
275
Is it possible to drill an additional well in a well?
258
Create a new topic
Create New Topic
Attach one or more files
Create New Topic
